| I did not realize that the messages are locked after 48 hrs.. Thanks for the comments and suggestions. I did not bleed the ABS actuators so I will try that tomorrow. Is there a trick to bleeding the ABS actuators? I also did not disconnect the battery so maybe that could be a cause also. When I disconnect the vacuum hose from the brake booster, the brake pedal does not go to the floor when the car is on or off. It feels firm. the brake pedal only goes to the floor when the car is on with the vacuum line connected to the brake booster. Regarding the valve comment, it is not possible to connect it backward because I did not remove the hose on the engine side. I did check the valve and it works properly. Thanks all in advance
